Einleitung
Outline what you are going to teach someone how to do.
Was du brauchst
Remove the three screws running along the back edge of case cover.
Remove the two screws from each side of the case cover.
Grab edges of the cover with your hands. Pull outward slightly, then straight up.
Be sure case cover has been removed prior to back panel removal.
Remove 5 screws from panel, as shown.
Use flat-head screwdriver to push in square tabs, located on each side of the back panel.
Use caution, the edges are sharp.
Eine weitere Person hat diese Anleitung absolviert.
