Zum Hauptinhalt wechseln
Replacing Atari Lynx Speaker
Was du brauchst
  1. Replacing Atari Lynx Speaker, Atari Lynx: Schritt 1, Bild 1 von 1
    • Before disassembling your Atari Lynx, be sure the device is powered off.
    • Remove any game in the console by opening the right latch and sliding the game to the right.
  2. Replacing Atari Lynx Speaker: Schritt 2, Bild 1 von 1
    • Remove the four 35 mm Phillips #1 screws at each corner of the backside on the Atari Lynx.
    • Pinch the rear panel with your fingers and lift away from the Atari.
  3. Replacing Atari Lynx Speaker: Schritt 3, Bild 1 von 1
    • Remove the battery panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear any wires attached to battery panel.
  4. Replacing Atari Lynx Speaker: Schritt 4, Bild 1 von 1
    • Remove the control panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear the speaker wire while removing the control panel.
  5. Replacing Atari Lynx Speaker, Speaker: Schritt 5, Bild 1 von 2 Replacing Atari Lynx Speaker, Speaker: Schritt 5, Bild 2 von 2
    • Remove the logic board from the console.
    • Flip the logic board so the screen is facing down.
  6. Replacing Atari Lynx Speaker: Schritt 6, Bild 1 von 2 Replacing Atari Lynx Speaker: Schritt 6, Bild 2 von 2
    • Now you will need to desolder both of the wires connected to the speaker.
    • If you are having trouble desoldering, click here.
    • Finally solder the new speaker back on and follow the previous steps in reverse order.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 1-42, Maness Winter 2014 Mitglied von Cal Poly, Team 1-42, Maness Winter 2014
CPSU-MANESS-W14S1G42
5 Mitglieder
16 Anleitungen geschrieben
2 Kommentare
Does anyone know the screw sizes for the lynx 2 console please
RBKing 80 - Antwort
What are the specs on the speaker? Size? Wattage?
gregory draudt - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 8
Insgesamt: 1,409
