Zum Hauptinhalt wechseln
Replacing Nexus 7 Solution to no power up after a drop
  1. Replacing Nexus 7 Solution to no power up after a drop, Solution to no power up after a drop: Schritt 1, Bild 1 von 1
    • Note battery compartment slightly larger than battery. 1/8" reveal on left side if off after top of battery shifted.
Abschluss
33 weitere Nutzer:innen haben diese Anleitung absolviert.
4 Kommentare
What do I actually do?
Ben - Antwort
I just did this after dropping my Nexus 7 and experiencing the screen flicker.
Take the back cover off as described here
Nexus 7 Akku tauschen
Ensure the battery plug is connected well. Straighten the battery back up. Worked perfectly.
Rich - Antwort
just tried this, couldn`t find the right tool so used a 1mm guitar pick and credit card. worked perfectly and now my Nexus is working again. thanks.
gaz keenan - Antwort
Nice fix- had same issue, fixed it in 5 min! Thx
Jay Jay - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 28
Insgesamt: 20,072
