Einleitung
Before starting this guide you may need some experience with soldering/ desoldering. If you do not know how, you can learn by clicking the link on step 5 (when you have to desolder the aluminum tabs).
Was du brauchst
Before disassembling your Atari Lynx, be sure the device is powered off.
Remove any game in the console by opening the right latch and sliding the game to the right.
Remove the four 35 mm Phillips #1 screws at each corner of the backside on the Atari Lynx.
Pinch the rear panel with your fingers and lift away from the Atari.
Remove the battery panel by pinching the sides with your fingers and lifting it away from the Atari.
Remove the control panel by pinching the sides with your fingers and lifting it away from the Atari.
Desolder the four aluminum tabs and for more information on soldering click here.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
