Zum Hauptinhalt wechseln
Retroid Pocket 3 Battery Replacement
Was du brauchst
  1. Retroid Pocket 3 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Unplug any cables connected to the Retroid Pocket 3+.
    • Ensure your device has a charge of 5% or less as a charged battery can be dangerous if punctured.
  2. Retroid Pocket 3 Battery Replacement: Schritt 2, Bild 1 von 3 Retroid Pocket 3 Battery Replacement: Schritt 2, Bild 2 von 3 Retroid Pocket 3 Battery Replacement: Schritt 2, Bild 3 von 3
    • Remove the four 6 mm screws from the backplate of the device with a T5 Torx screwdriver.
    • Use a plastic opening tool or spudger to gently pry apart the backplate from the device.
  3. Retroid Pocket 3 Battery Replacement: Schritt 3, Bild 1 von 2 Retroid Pocket 3 Battery Replacement: Schritt 3, Bild 2 von 2
    • Remove the four 4.5 mm screws with a Phillips #00 screwdriver.
    • Lift off the metal plate.
  4. Retroid Pocket 3 Battery Replacement: Schritt 4, Bild 1 von 3 Retroid Pocket 3 Battery Replacement: Schritt 4, Bild 2 von 3 Retroid Pocket 3 Battery Replacement: Schritt 4, Bild 3 von 3
    • Use a plastic opening tool or spudger to unclip the battery connector.
    • Carefully lift the battery from the case.
    • The battery has double-sided tape at the bottom. Gently push a spudger or opening tool underneath the battery to help free it from the adhesive. Do not bend or puncture the battery.
    • Lift and remove the battery.
Abschluss
Cassidy Anderson
241 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 9
Letzte 7 Tage: 30
Letzte 30 Tage: 68
Insgesamt: 123
