Zum Hauptinhalt wechseln
Revlon RVDR5061 Heating Element Assembly Replacement
Was du brauchst
  1. Revlon RVDR5061 Heating Element Assembly Replacement, Fan/Motor Assembly: Schritt 1, Bild 1 von 1
    • Using a Phillips #3 screwdriver, remove the single 25 mm Phillips head screw in the handle by turning it counterclockwise.
  2. Revlon RVDR5061 Heating Element Assembly Replacement: Schritt 2, Bild 1 von 1
    • Using a medium flathead screwdriver or better yet iFixit plastic opening tools, gently pry apart the handle from the power cord.
  3. Revlon RVDR5061 Heating Element Assembly Replacement: Schritt 3, Bild 1 von 1
    • After pulling apart the housing, all internals will be free to remove.
  4. Revlon RVDR5061 Heating Element Assembly Replacement: Schritt 4, Bild 1 von 3 Revlon RVDR5061 Heating Element Assembly Replacement: Schritt 4, Bild 2 von 3 Revlon RVDR5061 Heating Element Assembly Replacement: Schritt 4, Bild 3 von 3
    • The fan/motor assembly is connected to the heating element assembly at two points need to be desoldered. After pulling the attached wires through the holes the fan/motor assembly will be free from the heating element assembly. Congratulations you have now completely removed the fan/motor assembly from this hair dryer!
  5. Revlon RVDR5061 Heating Element Assembly Replacement, Heating Element Assembly: Schritt 5, Bild 1 von 2 Revlon RVDR5061 Heating Element Assembly Replacement, Heating Element Assembly: Schritt 5, Bild 2 von 2
    • Once the fan/motor assembly is disconnected from the heating element assembly you will see that the heating element assembly is connected to a circuit board by four wires. The color of these wires are grey, black, purple and brown.
  6. Revlon RVDR5061 Heating Element Assembly Replacement: Schritt 6, Bild 1 von 3 Revlon RVDR5061 Heating Element Assembly Replacement: Schritt 6, Bild 2 von 3 Revlon RVDR5061 Heating Element Assembly Replacement: Schritt 6, Bild 3 von 3
    • Desolder these four wires one by one from the circuit board.
  7. Revlon RVDR5061 Heating Element Assembly Replacement: Schritt 7, Bild 1 von 1
    • The heating element assembly will now be separated from the circuit board and can be replaced with a new one.
Abschluss
Soneil Pitamber
97 Reputation
1 Anleitung geschrieben
IUPUI, Team S2-G2, Wilson Summer 2018 Mitglied von IUPUI, Team S2-G2, Wilson Summer 2018
IUPUI-WILSON-SU18S2G2
4 Mitglieder
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 5
Letzte 30 Tage: 18
Insgesamt: 786
