Einleitung
The foldable handle is part of what made the Super 8 camera iconic. The intuitive and easily stored design allowed for steady on-the-go filming.
Was du brauchst
Open the handle's battery compartment and remove the batteries from the handle.
Using the Phillips #000 screwdriver, remove the three screws on the round plate on the right side of the camera handle. This is the side with the handle lock release button.
Remove the round metal plate.
Then, shift the handle so you have clearance to pass one of the legs of the button through the opening.
Flip the camera to the other side and remove the screws from the other round metal plate with a Phillips #000 screwdriver.
Pull the handle slowly away from the camera and shift the handle to allow access to the wire connections.
Desolder these wires carefully and you can now remove the handle.
