Zum Hauptinhalt wechseln
Ridgid GEN5X R8642 Battery Port Replacement
Was du brauchst
  1. Ridgid GEN5X R8642 Battery Port Replacement, Battery Port: Schritt 1, Bild 1 von 1
    • Remove the plastic tab holding the handle cover in place by prying upward with the spudger until the tab pops off.
  2. Ridgid GEN5X R8642 Battery Port Replacement: Schritt 2, Bild 1 von 1
    • Remove the handle cover by pulling it towards the front of the saw.
    • The grip can sometimes become stuck and may require a decent amount of force to remove.
  3. Ridgid GEN5X R8642 Battery Port Replacement: Schritt 3, Bild 1 von 3 Ridgid GEN5X R8642 Battery Port Replacement: Schritt 3, Bild 2 von 3 Ridgid GEN5X R8642 Battery Port Replacement: Schritt 3, Bild 3 von 3
    • Use a T20 Torx screwdriver to remove the nine M4 X 16mm screws from the plastic housing.
  4. Ridgid GEN5X R8642 Battery Port Replacement: Schritt 4, Bild 1 von 1
    • Use a JIS #1 screwdriver to remove the two M4 x 25mm screws on both sides of the metal housing.
  5. Ridgid GEN5X R8642 Battery Port Replacement: Schritt 5, Bild 1 von 1
    • Remove one half of the plastic housing using a spudger so that the internal system is exposed.
  6. Ridgid GEN5X R8642 Battery Port Replacement: Schritt 6, Bild 1 von 1
    • Remove the plastic wire covers to the red and black connections on the switch assembly.
    • When you remove the wire covers, you should be able to see the solder on the wires.
    • Desolder the connections on both the red and black wire using a soldering iron.
    • Once the solder is removed, pull out the wires with the battery port attached to the wires.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 7
Insgesamt: 376
