Zum Hauptinhalt wechseln
Ridgid R82005 Motor Replacement
Was du brauchst
  1. Ridgid R82005  Motor Replacement, Housing Assembly: Schritt 1, Bild 1 von 1
    • Eject the battery from the drill.
    • Unscrew the seven M3x15.3mm screws, with the 2mm hex screwdriver bit, that secures the Housing Assembly.
  2. Ridgid R82005  Motor Replacement: Schritt 2, Bild 1 von 1
    • Push the metallic Housing Connecting clip out with flat side of the plastic opening tool.
    • Eject battery before attempting this step.
  3. Ridgid R82005  Motor Replacement: Schritt 3, Bild 1 von 2 Ridgid R82005  Motor Replacement: Schritt 3, Bild 2 von 2
    • Remove the top half of the Housing Assembly.
  4. Ridgid R82005  Motor Replacement: Schritt 4, Bild 1 von 2 Ridgid R82005  Motor Replacement: Schritt 4, Bild 2 von 2
    • Grasp carefully the top and bottom of drill components.
    • LED light needs to be manually removed.
    • Lift and transfer, as a whole, the drill components from the old housing assembly to the new housing.
    • Make sure all drill components fit properly in the grooves of new Housing Assembly.
  5. Ridgid R82005  Motor Replacement, Motor: Schritt 5, Bild 1 von 3 Ridgid R82005  Motor Replacement, Motor: Schritt 5, Bild 2 von 3 Ridgid R82005  Motor Replacement, Motor: Schritt 5, Bild 3 von 3
    • Push the two pins through the motor assembly.
    • We used an Alan wrench to push the pins through, but any small tool will do.
    • Unsolder the wires from the back of the motor to free the motor from the trigger assembly.
    • To learn how to solder, check out the How to Solder and Desolder Connections guide.
    • Make sure all drill components fit properly in the grooves of the Housing Assembly.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team S1-G2, Leahy Spring 2019 Mitglied von USF Tampa, Team S1-G2, Leahy Spring 2019
USFT-LEAHY-S19S1G2
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 20
Insgesamt: 809
