Einleitung
A defective drill trigger can unintentionally keep the drill on when used by operators and this safety hazard increases the chances of accidental punctures to nearby objects.
Was du brauchst
Eject the battery from the drill.
Unscrew the seven M3x15.3mm screws, with the 2mm hex screwdriver bit, that secures the Housing Assembly.
Push the metallic Housing Connecting clip out with flat side of the plastic spudger.
Motor Assembly/Gearbox and Trigger Switch removed from Housing Assembly.
Desolder the black wire connected to the motor.
Flip Trigger Switch and desolder red wire.
2 weitere Personen haben diese Anleitung absolviert.
