Zum Hauptinhalt wechseln
Roku 2 A/C Power Port Replacement
Was du brauchst
  1. Roku 2  A/C Power Port Replacement, Roku 2 Motherboard: Schritt 1, Bild 1 von 1
    • Heat up the iOpener for 30 seconds in the microwave and place across rubber pads on the back of the device.
    • It may take multiple heats, left for a minute at a time, to properly loosen the glue.
  2. Roku 2  A/C Power Port Replacement: Schritt 2, Bild 1 von 1
    • Gently use the plastic opening tool to pry the rubber pads off.
  3. Roku 2  A/C Power Port Replacement: Schritt 3, Bild 1 von 1
    • Remove the four Phillips #000 screws from the bottom of the case.
  4. Roku 2  A/C Power Port Replacement: Schritt 4, Bild 1 von 1
    • Gently remove the under side of the device.
  5. Roku 2  A/C Power Port Replacement: Schritt 5, Bild 1 von 1
    • Remove the middle component that is held in place by the top and bottom of the device.
  6. Roku 2  A/C Power Port Replacement: Schritt 6, Bild 1 von 1
    • Remove the cover over the A/V ports on the front of the device.
  7. Roku 2  A/C Power Port Replacement: Schritt 7, Bild 1 von 1
    • Remove the board from the plastic enclosure.
  8. Roku 2  A/C Power Port Replacement, A/C Power Port: Schritt 8, Bild 1 von 1
    • Heat the 3 solder leads on the bottom side of the motherboard opposite of the A/C Port until the point you can pull the port away from the board.
    • To learn more about soldering check out the Soldering Technique Guide.
  9. Roku 2  A/C Power Port Replacement: Schritt 9, Bild 1 von 1
    • Insert the new A/C power port where the old one was. Gently apply solder to the 3 pins on the bottom side of the mother board to connect it.
Abschluss
david quintana
101 Reputation
1 Anleitung geschrieben
USF Tampa, Team 1-5, Sullivan Fall 2015 Mitglied von USF Tampa, Team 1-5, Sullivan Fall 2015
USFT-SULLIVAN-F15S1G5
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 14
Insgesamt: 1,318
