Einleitung
This guide will demonstrate how to remove and replace the A/C power port. Be sure to check out the Soldering Technique Guide to learn ore about soldering before completing this repair.
Was du brauchst
Heat up the iOpener for 30 seconds in the microwave and place across rubber pads on the back of the device.
Remove the middle component that is held in place by the top and bottom of the device.
Heat the 3 solder leads on the bottom side of the motherboard opposite of the A/C Port until the point you can pull the port away from the board.
Insert the new A/C power port where the old one was. Gently apply solder to the 3 pins on the bottom side of the mother board to connect it.
