Einleitung
Replace a broken or faulty power jack for your Roku 3. The Roku 3 cannot power on without a functioning power jack.
Was du brauchst
Place the Roku 3 on the table face down and orient it so you can correctly read the writing.
Pull back the rubber protection in the top right corner to locate the screw.
Repeat with the bottom right corner and bottom left corner.
Open the device by gently lifting the bottom half away from the top half of the device.
Use your fingers to carefully lift the motherboard from the top half of the device.
Turn over the motherboard so the back is face up and almost all large silver components are resting facedown on the table.
Orient it such that the backside of the HDMI port is in your upper right corner.
Desolder the connections of the A/C Power Port on the motherboard.
Remove the port.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
What’s the size and name of the actual jack? Where do I get a replacement one?
