Zum Hauptinhalt wechseln
Roku 3 Ethernet Port Replacement
Was du brauchst
  1. Roku 3 Ethernet Port Replacement, Motherboard: Schritt 1, Bild 1 von 1
    • Place the Roku 3 on the table face down and orient it so you can correctly read the writing.
  2. Roku 3 Ethernet Port Replacement: Schritt 2, Bild 1 von 3 Roku 3 Ethernet Port Replacement: Schritt 2, Bild 2 von 3 Roku 3 Ethernet Port Replacement: Schritt 2, Bild 3 von 3
    • Pull back the rubber protection in the top right corner to locate the screw.
    • Repeat with the bottom right corner and bottom left corner.
  3. Roku 3 Ethernet Port Replacement: Schritt 3, Bild 1 von 1
    • Remove the 9 mm screws from the three corners with a Hex 1.3 Screwdriver.
  4. Roku 3 Ethernet Port Replacement: Schritt 4, Bild 1 von 2 Roku 3 Ethernet Port Replacement: Schritt 4, Bild 2 von 2
    • Open the device by gently lifting the bottom half away from the top half of the device.
  5. Roku 3 Ethernet Port Replacement: Schritt 5, Bild 1 von 1
    • Use your fingers to carefully lift the motherboard from the top half of the device.
  6. Roku 3 Ethernet Port Replacement: Schritt 6, Bild 1 von 2 Roku 3 Ethernet Port Replacement: Schritt 6, Bild 2 von 2
    • Pull away the IO shield from the motherboard using your hands.
  7. Roku 3 Ethernet Port Replacement, Ethernet Port: Schritt 7, Bild 1 von 2 Roku 3 Ethernet Port Replacement, Ethernet Port: Schritt 7, Bild 2 von 2
    • Turn over the motherboard so the back is face up and almost all large silver components are resting facedown on the table.
    • Orient it such that the backside of the HDMI port is in your upper right corner.
  8. Roku 3 Ethernet Port Replacement: Schritt 8, Bild 1 von 1
    • Desolder all of the port's connections with a soldering iron.
    • For more information on soldering, check out iFixit's Soldering Guide.
  9. Roku 3 Ethernet Port Replacement: Schritt 9, Bild 1 von 2 Roku 3 Ethernet Port Replacement: Schritt 9, Bild 2 von 2
    • Locate the plastic push-throughs just to the left of the backside of the USB port.
    • Pinch the plastic push-throughs. The port should now be able to be removed.
Abschluss
Andy Hak
250 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 15-2, Livingston Fall 2016 Mitglied von Cal Poly, Team 15-2, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G2
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 16
Insgesamt: 1,601
