Einleitung
The ethernet port serves as a temporary or permanent solution to connecting to the internet on a network that does have have WiFi. Follow this guide to replace your broken or faulty ethernet port.
Was du brauchst
Place the Roku 3 on the table face down and orient it so you can correctly read the writing.
Pull back the rubber protection in the top right corner to locate the screw.
Repeat with the bottom right corner and bottom left corner.
Open the device by gently lifting the bottom half away from the top half of the device.
Use your fingers to carefully lift the motherboard from the top half of the device.
Turn over the motherboard so the back is face up and almost all large silver components are resting facedown on the table.
Orient it such that the backside of the HDMI port is in your upper right corner.
Locate the plastic push-throughs just to the left of the backside of the USB port.
Pinch the plastic push-throughs. The port should now be able to be removed.
