Zum Hauptinhalt wechseln
Roku XD 2050X Audio Port Replacement
Was du brauchst
  1. Roku XD 2050X Audio Port Replacement, Case: Schritt 1, Bild 1 von 3 Roku XD 2050X Audio Port Replacement, Case: Schritt 1, Bild 2 von 3 Roku XD 2050X Audio Port Replacement, Case: Schritt 1, Bild 3 von 3
    • Ensure the Roku XDis unplugged.
    • Take care when handling components. Circuit boards, soldering points, and other areas may have sharp points.
    • Turn the device upside down.
    • Remove the two rubber pads using a plastic spudger.
  2. Roku XD 2050X Audio Port Replacement: Schritt 2, Bild 1 von 2 Roku XD 2050X Audio Port Replacement: Schritt 2, Bild 2 von 2
    • Remove the two Phillips #1 9mm pan-head screws.
  3. Roku XD 2050X Audio Port Replacement: Schritt 3, Bild 1 von 3 Roku XD 2050X Audio Port Replacement: Schritt 3, Bild 2 von 3 Roku XD 2050X Audio Port Replacement: Schritt 3, Bild 3 von 3
    • Insert spudger between upper and lower frame underneath the port access.
    • Guide spudger around to loosen upper and lower frame to pry frame apart.
    • Gently remove upper frame.
  4. Roku XD 2050X Audio Port Replacement: Schritt 4, Bild 1 von 2 Roku XD 2050X Audio Port Replacement: Schritt 4, Bild 2 von 2
    • Remove the two Phillips #1 8mm pan-head screws.
  5. Roku XD 2050X Audio Port Replacement: Schritt 5, Bild 1 von 1
    • On the side of the board opposite the ports, find and tilt back the tab securing the board in place.
    • Lift the motherboard out of the lower frame.
  6. Roku XD 2050X Audio Port Replacement, Audio Port: Schritt 6, Bild 1 von 1
    • Desolder the leads for the audio port that you wish to replace.
    • Left audio port leads are circled in red.
    • Right audio port leads are circled in orange.
    • Remove the audio port from board.
    • For help with soldering view the iFixit soldering guide.
Abschluss
William
1.603 Reputation
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 10
Insgesamt: 443
