Einleitung
In this guide we will show you how to replace the Ethernet port on your Roku XD 2050X. To complete this guide, you will need to disassemble your device and use a soldering iron to replace the port.
Was du brauchst
Turn the device upside down.
Remove the two rubber pads using a plastic spudger.
Insert spudger between upper and lower frame underneath the port access.
Guide spudger around to loosen upper and lower frame to pry frame apart.
Gently remove upper frame.
On the side of the board opposite the ports, find and tilt back the tab securing the board in place.
Lift the motherboard out of the lower frame.
Desolder the 8 contact points.
For help with soldering view the iFixit soldering guide.
Use pliers to pinch the two anchor points and gently press them through the board to separate ethernet port.
Remove the Ethernet port from board.
Eine weitere Person hat diese Anleitung absolviert.
