Zum Hauptinhalt wechseln
Roku XD 2050X Remote Battery Terminal Replacement
Was du brauchst
  1. Roku XD 2050X Remote Battery Terminal Replacement, Remote Control Casing: Schritt 1, Bild 1 von 2 Roku XD 2050X Remote Battery Terminal Replacement, Remote Control Casing: Schritt 1, Bild 2 von 2
    • Take care when handling components. Circuit boards, soldering points, and other areas may have sharp points.
    • Remove the battery cover.
    • Remove the two AA batteries.
  2. Roku XD 2050X Remote Battery Terminal Replacement: Schritt 2, Bild 1 von 2 Roku XD 2050X Remote Battery Terminal Replacement: Schritt 2, Bild 2 von 2
    • Insert flat edge of spudger into seam between the top and bottom halves of the remote control.
    • Gently twist the spudger to separate the top and bottom halves of the remote.
  3. Roku XD 2050X Remote Battery Terminal Replacement: Schritt 3, Bild 1 von 1
    • Gently use the spudger to pry the circuit board loose.
  4. Roku XD 2050X Remote Battery Terminal Replacement: Schritt 4, Bild 1 von 1
    • Using either end of the spudger, gently lift and remove the clear keypad backing.
  5. Roku XD 2050X Remote Battery Terminal Replacement: Schritt 5, Bild 1 von 1
    • Using either end of the spudger, lift and remove the rubber keypad.
  6. Roku XD 2050X Remote Battery Terminal Replacement, Remote Battery Terminal: Schritt 6, Bild 1 von 1
    • Desolder the contacts for the battery terminals.
    • Remove the battery terminals from the circuit board.
    • For hep with soldering view the ifixit soldering guide.
Abschluss
William
1.603 Reputation
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 17
Insgesamt: 1,243
