Einleitung
This guide will show you how to properly access the internals to the motor housing to your Ryobi CSB125 circular saw. If you hear a humming noise when pressing the trigger, or while operating the saw smoke forms, then most likely the motor has gone bad. This troubleshooting page will help diagnose any potential problems occurring due to a faulty motor. In the event that a new motor is needed, this guide will show the steps to properly install a new one. The only tools you will need are a #2 Phillips screwdriver, a 7”/32 allen key, and a T20 torx screwdriver.
Was du brauchst
Remove the bumper by using the T20 torx screwdriver to loosen the M5 x 20mm screw.
Remove the 5/16-18 x 9/16 in. blade screw, spring washer, the outer blade washer, the blade, and the inner blade washer.
Flip the saw over and place the saw down on a flat surface with the motor facing up.
Use the Phillips #2 screwdriver to remove the two M4x16mm screws holding down the end cover.
Pull off the end cover.
Use the Phillips #2 screwdriver to remove the M45x35mm screw holding down the motor housing.
3 weitere Personen haben diese Anleitung absolviert.
