Zum Hauptinhalt wechseln
Ryobi CSB125 Power Cord Replacement
Was du brauchst
  1. Ryobi CSB125 Power Cord Replacement, Power Cord: Schritt 1, Bild 1 von 1
    • Place the saw down on a flat surface with the motor facing up.
    • Make sure that the saw is unplugged from any power source.
  2. Ryobi CSB125 Power Cord Replacement: Schritt 2, Bild 1 von 2 Ryobi CSB125 Power Cord Replacement: Schritt 2, Bild 2 von 2
    • Use the Phillips #2 screwdriver to remove the five M4x16mm screws.
  3. Ryobi CSB125 Power Cord Replacement: Schritt 3, Bild 1 von 1
    • Use the Phillips #2 screwdriver to remove the two M45x35mm screws.
  4. Ryobi CSB125 Power Cord Replacement: Schritt 4, Bild 1 von 2 Ryobi CSB125 Power Cord Replacement: Schritt 4, Bild 2 von 2
    • To remove the plug from the saw you will need to disconnect the two wires that come from the plug.
    • Remove the black wire by unscrewing it from the trigger switch using the Phillips #2 screwdriver.
    • Remove the white wire by twisting off the plastic wire nut to separate the two white wires.
  5. Ryobi CSB125 Power Cord Replacement: Schritt 5, Bild 1 von 1
    • Remove the plug from the saw.
    • You may have to use the wire strippers to expose the copper on the new plug.
    • It is important that the wires are properly run in their tracks. Failure to do so could result in pinching a wire, which could damage the plug.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Curtis Melo
1.066 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team S2-G1, Barthe Fall 2019 Mitglied von UMass Dartmouth, Team S2-G1, Barthe Fall 2019
UMASSD-BARTHE-F19S2G1
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 9
Letzte 30 Tage: 27
Insgesamt: 1,585
