Zum Hauptinhalt wechseln
Ryobi CSB135L Laser Replacement
Was du brauchst
  1. Ryobi CSB135L Laser Replacement, Motor Housing: Schritt 1, Bild 1 von 1
    • Remove the three M4.5 x 35mm screws that hold the motor housing to the blade housing using a Phillips screwdriver.
    • Although not required for motor housing removal, the two M4 x 16 mm Phillips head screws must be removed for access to the top of the motor.
  2. Ryobi CSB135L Laser Replacement: Schritt 2, Bild 1 von 1
    • Remove the three M3.5 x 16 mm screws that hold on the laser cover using a Phillips screwdriver.
    • The wires that power the laser prevent the motor housing from coming off, so the laser must be removed.
  3. Ryobi CSB135L Laser Replacement: Schritt 3, Bild 1 von 1
    • Pry the motor housing (green plastic) from the blade housing (gray plastic) using a metal spudger or any small pry bar.
  4. Ryobi CSB135L Laser Replacement: Schritt 4, Bild 1 von 1
    • Fully remove the motor housing and blade cover to expose the motor and laser.
  5. Ryobi CSB135L Laser Replacement, Laser: Schritt 5, Bild 1 von 1
    • Regardless of the assembly state of the saw, remove the M4 x 16 mm screws that hold the two pieces of the handle together using a Phillips screwdriver.
  6. Ryobi CSB135L Laser Replacement: Schritt 6, Bild 1 von 1
    • Unplug the laser from the handle.
  7. Ryobi CSB135L Laser Replacement: Schritt 7, Bild 1 von 1
    • Remove the laser that is woven through the plastic of the saw's handle.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
UMass Dartmouth, Team 7-3, Ryckebusch Spring 2023 Mitglied von UMass Dartmouth, Team 7-3, Ryckebusch Spring 2023
UMASSD-RYCKEBUSCH-S23S7G3
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 16
Insgesamt: 147
