Einleitung
This guide will show you how to properly replace the power cord in the Ryobi CSB135L. If the symptoms in our troubleshooting page for a damaged power cord align with the symptoms your Ryobi CSB135L are experiencing your power cord is most likely damaged.
Was du brauchst
Remove the six M4x16mm Phillips screws and the two M4.5x35mm screws using a Phillips #2 screwdriver.
Remove the front facing half of the handle assembly exposing the internals of the saw.
After removing the handle assembly locate the trigger switch and wire nut in the saw.
Remove the screw from the black wire of the power cord using a Phillips screwdriver. Then remove the wire.
Loosen the wire nut and remove the neutral wire from the power cord.
