Zum Hauptinhalt wechseln
Ryobi CSB135L Power Cord Replacement
Was du brauchst
  1. Ryobi CSB135L Power Cord Replacement, Power Cord: Schritt 1, Bild 1 von 1
    • Place the saw on a flat surface.
    • Make sure the saw is unplugged and unpowered.
  2. Ryobi CSB135L Power Cord Replacement: Schritt 2, Bild 1 von 2 Ryobi CSB135L Power Cord Replacement: Schritt 2, Bild 2 von 2
    • Remove the six M4x16mm Phillips screws and the two M4.5x35mm screws using a Phillips #2 screwdriver.
    • Remove the front facing half of the handle assembly exposing the internals of the saw.
  3. Ryobi CSB135L Power Cord Replacement: Schritt 3, Bild 1 von 2 Ryobi CSB135L Power Cord Replacement: Schritt 3, Bild 2 von 2
    • After removing the handle assembly locate the trigger switch and wire nut in the saw.
    • Remove the screw from the black wire of the power cord using a Phillips screwdriver. Then remove the wire.
    • Loosen the wire nut and remove the neutral wire from the power cord.
  4. Ryobi CSB135L Power Cord Replacement: Schritt 4, Bild 1 von 1
    • Remove the power cord from the saw.
    • To insert the replacement power cord, insert the black wire of the cord into the trigger switch and tighten the screw. Take the neutral/white wire of the new cord and insert it into the wire nut and tighten the nut.
    • Wire strippers may be needed when installing the new power cord to expose the copper wire.
Abschluss
UMass Dartmouth, Team 7-3, Ryckebusch Spring 2023 Mitglied von UMass Dartmouth, Team 7-3, Ryckebusch Spring 2023
UMASSD-RYCKEBUSCH-S23S7G3
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 15
Insgesamt: 133
