Zum Hauptinhalt wechseln
Ryobi P516 Top Case Replacement
Was du brauchst
  1. Ryobi P516 Top Case Replacement, Top Case: Schritt 1, Bild 1 von 2 Ryobi P516 Top Case Replacement, Top Case: Schritt 1, Bild 2 von 2
    • Using the 5mm hex key included at the base of the saw, loosen the set screw at the front of the saw.
    • The front guard will now slide out from the front of the saw.
  2. Ryobi P516 Top Case Replacement: Schritt 2, Bild 1 von 3 Ryobi P516 Top Case Replacement: Schritt 2, Bild 2 von 3 Ryobi P516 Top Case Replacement: Schritt 2, Bild 3 von 3
    • Remove the two 10mm T20 Torx screws from the front of the saw.
    • Pull out the front plate.
  3. Ryobi P516 Top Case Replacement: Schritt 3, Bild 1 von 3 Ryobi P516 Top Case Replacement: Schritt 3, Bild 2 von 3 Ryobi P516 Top Case Replacement: Schritt 3, Bild 3 von 3
    • Start at the middle of the device and begin to pry up the rubber grip.
    • Pull the rubber portion inside out towards the front of the saw.
  4. Ryobi P516 Top Case Replacement: Schritt 4, Bild 1 von 1
    • Remove all twelve 14mm T20 Torx screws from the main case of the device.
  5. Ryobi P516 Top Case Replacement: Schritt 5, Bild 1 von 3 Ryobi P516 Top Case Replacement: Schritt 5, Bild 2 von 3 Ryobi P516 Top Case Replacement: Schritt 5, Bild 3 von 3
    • Remove the four 35mm Phillips #2 screws.
    • Pry the two case halves apart starting at the middle of the saw.
    • Watch out for any loose parts from inside the saw that may fall out during this step.
  6. Ryobi P516 Top Case Replacement: Schritt 6, Bild 1 von 1
    • Continue splitting the case until the top piece of the case is free and set it aside.
Abschluss
6 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
P516 blade locking parts
Bill clark - Antwort
P516 blade locking parts breakdown, please ?
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 14
Letzte 30 Tage: 69
Insgesamt: 4,191
