Was du brauchst
Turn off the device completely by holding the power button for 10-20 seconds to force a shutdown.
Remove the seven 4.1 mm screws from the back of the device using a T4 Torx screwdriver.
Remove the ten 2.9 mm screws from the motherboard using a T5 Torx screwdriver.
Carefully remove the motherboard, as it is connected to the battery underneath.
Desolder the battery cables from the motherboard.
Separate the motherboard from the rest of the device.
Abschluss
