Einleitung
This guide will show step by step how to replace the home button on a Samsung Galaxy Tab A 10.1 tablet.
Was du brauchst
Remove all external power and turn off the tablet.
Insert a plastic opening tool between the screen and rear casing.
Pry the screen and rear casing apart.
Remove the three green pieces of tape covering the white, black, and gold ribbon cables.
Use a spudger to flip up the retaining flap on the three ribbon cable ZIF sockets.
Pull the ribbon cables out of the sockets.
Remove the ten 4mm Phillips #000 screws from the battery.
Use a plastic opening tool to pry up the battery.
Remove the battery.
Remove the green protective tape from the three ZIF connectors on the motherboard.
Pull the ribbon cables out of their sockets.
Remove the six 4mm Phillips #000 screws from the motherboard.
Remove the motherboard.
Insert a plastic opening tool between the screen and bezel.
Slide the plastic opening tool around the perimeter while applying a prying motion.
Remove the screen from the display.
Locate the Home button on the front of the panel and carefully lift the gold ribbon surrounding it from RIGHT to LEFT.
Using your Phillips #000 screwdriver Remove the two 4mm Phillips #000 screws from the home button.
Eine weitere Person hat diese Anleitung absolviert.
