Zum Hauptinhalt wechseln
Samsung 27E510C Audio Jack Replacement
Was du brauchst
  1. Samsung 27E510C Audio Jack Replacement, Back Panel: Schritt 1, Bild 1 von 3 Samsung 27E510C Audio Jack Replacement, Back Panel: Schritt 1, Bild 2 von 3 Samsung 27E510C Audio Jack Replacement, Back Panel: Schritt 1, Bild 3 von 3
    • Use the #1 Phillips head screw driver to remove each 13.75mm length screw from the rear panel.
    • The screw alone with the ports is a different size than the rest, its length is 12mm.
  2. Samsung 27E510C Audio Jack Replacement: Schritt 2, Bild 1 von 2 Samsung 27E510C Audio Jack Replacement: Schritt 2, Bild 2 von 2
    • Insert the heavy duty spudger in between the monitors back panel and its frame.
    • Use the heavy duty spudger to pry open the back panel.
    • Over aggressive prying could break the tabs holding the back panel in place.
  3. Samsung 27E510C Audio Jack Replacement, Motherboard: Schritt 3, Bild 1 von 1
    • Remove the navigation button connector by pulling while holding down its thumb tab.
  4. Samsung 27E510C Audio Jack Replacement: Schritt 4, Bild 1 von 1
    • Remove the screen connector by gripping its sides and gently pulling while wiggling back and forth.
  5. Samsung 27E510C Audio Jack Replacement: Schritt 5, Bild 1 von 3 Samsung 27E510C Audio Jack Replacement: Schritt 5, Bild 2 von 3 Samsung 27E510C Audio Jack Replacement: Schritt 5, Bild 3 von 3
    • For the ribbon cable, Lift the tab from the side facing the inside of the mother board with your fingernail or a spudger.
    • Remove the cable by pulling while lifting slightly.
    • If the cable does not come out easily, than the secure tab may not be fully opened.
  6. Samsung 27E510C Audio Jack Replacement: Schritt 6, Bild 1 von 3 Samsung 27E510C Audio Jack Replacement: Schritt 6, Bild 2 von 3 Samsung 27E510C Audio Jack Replacement: Schritt 6, Bild 3 von 3
    • Remove each of the 5mm length screws attaching the motherboard to the body of the monitor using a #1 Phillips head screwdriver.
  7. Samsung 27E510C Audio Jack Replacement: Schritt 7, Bild 1 von 2 Samsung 27E510C Audio Jack Replacement: Schritt 7, Bild 2 von 2
    • Using both hands, lift the board off of the monitor body by the motherboards base.
  8. Samsung 27E510C Audio Jack Replacement, Audio Jack: Schritt 8, Bild 1 von 2 Samsung 27E510C Audio Jack Replacement, Audio Jack: Schritt 8, Bild 2 von 2
    • Desolder each of the indicated leads on the back of the motherboard.
  9. Samsung 27E510C Audio Jack Replacement: Schritt 9, Bild 1 von 2 Samsung 27E510C Audio Jack Replacement: Schritt 9, Bild 2 von 2
    • Squeeze the rear tabs located on the back of the motherboard with your thumb and index finger.
    • While squeezing both tabs, pull the audio jack out from the front of the motherboard.
    • The audio jack may be too hot to touch right after desoldering.
Abschluss
Cesar Morales
101 Reputation
1 Anleitung geschrieben
Cal Poly, Team S9-G1, Banghart Fall 2017 Mitglied von Cal Poly, Team S9-G1, Banghart Fall 2017
CPSU-BANGHART-F17S9G1
6 Mitglieder
14 Anleitungen geschrieben
Ein Kommentar
did you know port reference? @cesarmorales
Jorge Casanova - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 6
Insgesamt: 431
