Einleitung
In order to replace the battery, have a Phillips screwdriver handy. Make sure you are able to keep track of all the screws removed and where they belong (a magnetic project mat would be helpful). If your battery is damaged and needs to be replaced, replacement batteries should be purchased from the laptop's original manufacturing company (batteries can be bought online or in person from a Samsung retailer). Ensure that the battery is disposed of properly, according to your city's ordinances.
Was du brauchst
Turn the laptop upside down so that the underside of the laptop is facing you.
Use a Phillips #000 screwdriver to unscrew the 4.3 mm screws located on the edges and corners of the laptop.
Unscrew the four 4.55 mm Phillips #000 screws on the edges of the battery.
7 weitere Personen haben diese Anleitung absolviert.
4 Kommentare
http://www.myfixguide.com/manual/samsung...
There are no RAM modules. They are welded in the mother board.
Best regards!
any updated amazon product?
I just bought and installed this battery from Amazon: https://www.amazon.com/gp/product/B07NW7...
