Zum Hauptinhalt wechseln
Samsung BD-JM57C Power Cord Replacement
Was du brauchst
  1. Samsung BD-JM57C Power Cord Replacement, Top Cover: Schritt 1, Bild 1 von 2 Samsung BD-JM57C Power Cord Replacement, Top Cover: Schritt 1, Bild 2 von 2
    • Use the Phillips #00 Screwdriver to remove the single 9.6mm screw holding the top cover in place.
    • Remove the cover by sliding it up and then out.
  2. Samsung BD-JM57C Power Cord Replacement, Disc Drive: Schritt 2, Bild 1 von 2 Samsung BD-JM57C Power Cord Replacement, Disc Drive: Schritt 2, Bild 2 von 2
    • Disconnect the two ribbons that connect the disc drive to the motherboard.
  3. Samsung BD-JM57C Power Cord Replacement: Schritt 3, Bild 1 von 2 Samsung BD-JM57C Power Cord Replacement: Schritt 3, Bild 2 von 2
    • Push in on the two metal tabs on the side of the disc drive.
    • Push forward to slide the disc drive out of the casing.
  4. Samsung BD-JM57C Power Cord Replacement, WiFi Card: Schritt 4, Bild 1 von 2 Samsung BD-JM57C Power Cord Replacement, WiFi Card: Schritt 4, Bild 2 von 2
    • Pull clip to remove the WiFi card ribbon connected to the circuit board.
    • Push the black plastic tab out and slide the WiFi card out from the cage.
  5. Samsung BD-JM57C Power Cord Replacement, Power Cord: Schritt 5, Bild 1 von 2 Samsung BD-JM57C Power Cord Replacement, Power Cord: Schritt 5, Bild 2 von 2
    • Use the Phillips #00 Screwdriver to remove the two 6.4 mm screws holding the cage in place.
    • Lift the cage up to remove it.
  6. Samsung BD-JM57C Power Cord Replacement: Schritt 6, Bild 1 von 1
    • Push in the small white lever and pull it towards you to release the cord.
  7. Samsung BD-JM57C Power Cord Replacement: Schritt 7, Bild 1 von 1
    • Move the power cord out from under the metal tab on the side of the case.
  8. Samsung BD-JM57C Power Cord Replacement: Schritt 8, Bild 1 von 1
    • Remove the rubber spacer on the edge of the case holding the cord in place.
    • Remove the power cord from the device.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 13
Letzte 30 Tage: 14
Insgesamt: 198
