Zum Hauptinhalt wechseln
Samsung BD-JM57C Wi-Fi Card Replacement
Was du brauchst
  1. Samsung BD-JM57C Wi-Fi Card Replacement, Top Cover: Schritt 1, Bild 1 von 2 Samsung BD-JM57C Wi-Fi Card Replacement, Top Cover: Schritt 1, Bild 2 von 2
    • Use the Phillips #00 Screwdriver to remove the single 9.6mm screw holding the top cover in place.
    • Remove the cover by sliding it up and then out.
  2. Samsung BD-JM57C Wi-Fi Card Replacement, Disc Drive: Schritt 2, Bild 1 von 2 Samsung BD-JM57C Wi-Fi Card Replacement, Disc Drive: Schritt 2, Bild 2 von 2
    • Disconnect the two ribbons that connect the disc drive to the motherboard.
  3. Samsung BD-JM57C Wi-Fi Card Replacement: Schritt 3, Bild 1 von 2 Samsung BD-JM57C Wi-Fi Card Replacement: Schritt 3, Bild 2 von 2
    • Push in on the two metal tabs on the side of the disc drive.
    • Push forward to slide the disc drive out of the casing.
  4. Samsung BD-JM57C Wi-Fi Card Replacement, WiFi Card: Schritt 4, Bild 1 von 2 Samsung BD-JM57C Wi-Fi Card Replacement, WiFi Card: Schritt 4, Bild 2 von 2
    • Pull clip to remove the WiFi card ribbon connected to the circuit board.
    • Push the black plastic tab out and slide the WiFi card out from the cage.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Ein Kommentar
, please I don’t know if you can help me repair my Samsung bd blu ray player, it keeps showing wired connection and don’t let me connect on wireless, I will pay please
Latoya Jerry - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 18
Insgesamt: 286
