Zum Hauptinhalt wechseln
Samsung Chromebook 3 Daughterboard Replacement
Was du brauchst
  1. Samsung Chromebook 3 Daughterboard Replacement, Bottom Case: Schritt 1, Bild 1 von 2 Samsung Chromebook 3 Daughterboard Replacement, Bottom Case: Schritt 1, Bild 2 von 2
    • Place the Chromebook face down so that the bottom case is exposed.
    • Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
  2. Samsung Chromebook 3 Daughterboard Replacement: Schritt 2, Bild 1 von 3 Samsung Chromebook 3 Daughterboard Replacement: Schritt 2, Bild 2 von 3 Samsung Chromebook 3 Daughterboard Replacement: Schritt 2, Bild 3 von 3
    • Use a iFixit opening tool to gently pry the case up from the vent on the hinge side of the Chromebook.
    • You should hear a popping sound as the connectors disengage inside the case.
  3. Samsung Chromebook 3 Daughterboard Replacement: Schritt 3, Bild 1 von 1
    • Lift the case up and off the device
  4. Samsung Chromebook 3 Daughterboard Replacement, Battery: Schritt 4, Bild 1 von 2 Samsung Chromebook 3 Daughterboard Replacement, Battery: Schritt 4, Bild 2 von 2
    • Locate the battery and remove the four 4.6mm screws at the corners which attach it to case using a Phillips #00 screwdriver.
  5. Samsung Chromebook 3 Daughterboard Replacement: Schritt 5, Bild 1 von 2 Samsung Chromebook 3 Daughterboard Replacement: Schritt 5, Bild 2 von 2
    • Use a spudger to gently pry the power cable cord upwards from the motherboard.
  6. Samsung Chromebook 3 Daughterboard Replacement: Schritt 6, Bild 1 von 1
    • Lift the battery up and out from the case.
  7. Samsung Chromebook 3 Daughterboard Replacement, Daughterboard: Schritt 7, Bild 1 von 2 Samsung Chromebook 3 Daughterboard Replacement, Daughterboard: Schritt 7, Bild 2 von 2
    • Before you begin the process of removing the daughterboard, you will need to remove the port case. Using a Phillips #00 screwdriver, remove the three 4.6mm screws.
  8. Samsung Chromebook 3 Daughterboard Replacement: Schritt 8, Bild 1 von 2 Samsung Chromebook 3 Daughterboard Replacement: Schritt 8, Bild 2 von 2
    • Use a spudger to unhook the cable connecter from the speaker cable.
  9. Samsung Chromebook 3 Daughterboard Replacement: Schritt 9, Bild 1 von 3 Samsung Chromebook 3 Daughterboard Replacement: Schritt 9, Bild 2 von 3 Samsung Chromebook 3 Daughterboard Replacement: Schritt 9, Bild 3 von 3
    • Pry the small coaxial cables upwards from the connecters on the wireless chip.
  10. Samsung Chromebook 3 Daughterboard Replacement: Schritt 10, Bild 1 von 2 Samsung Chromebook 3 Daughterboard Replacement: Schritt 10, Bild 2 von 2
    • Using the Phillips #00, unscrew one 4.6mm screw from the daughterboard.
  11. Samsung Chromebook 3 Daughterboard Replacement: Schritt 11, Bild 1 von 3 Samsung Chromebook 3 Daughterboard Replacement: Schritt 11, Bild 2 von 3 Samsung Chromebook 3 Daughterboard Replacement: Schritt 11, Bild 3 von 3
    • Use a spudger to lift the gray plastic bar on the zif connecter up, then use your fingers to remove the cable ribbon.
  12. Samsung Chromebook 3 Daughterboard Replacement: Schritt 12, Bild 1 von 1
    • Loosen the daughterboard from the USB port with a spudger as there is some adhesive underneath, and you're ready to remove the daughterboard.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Sarah Westberg
23.272 Reputation
70 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
136 Mitglieder
17.299 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 23
Insgesamt: 1,203
