Zum Hauptinhalt wechseln
Samsung Chromebook 3 Motherboard Replacement
Was du brauchst
  1. Samsung Chromebook 3 Motherboard Replacement, Bottom Case: Schritt 1, Bild 1 von 2 Samsung Chromebook 3 Motherboard Replacement, Bottom Case: Schritt 1, Bild 2 von 2
    • Place the Chromebook face down so that the bottom case is exposed.
    • Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
  2. Samsung Chromebook 3 Motherboard Replacement: Schritt 2, Bild 1 von 3 Samsung Chromebook 3 Motherboard Replacement: Schritt 2, Bild 2 von 3 Samsung Chromebook 3 Motherboard Replacement: Schritt 2, Bild 3 von 3
    • Use a iFixit opening tool to gently pry the case up from the vent on the hinge side of the Chromebook.
    • You should hear a popping sound as the connectors disengage inside the case.
  3. Samsung Chromebook 3 Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Lift the case up and off the device
  4. Samsung Chromebook 3 Motherboard Replacement, Battery: Schritt 4, Bild 1 von 2 Samsung Chromebook 3 Motherboard Replacement, Battery: Schritt 4, Bild 2 von 2
    • Locate the battery and remove the four 4.6mm screws at the corners which attach it to case using a Phillips #00 screwdriver.
  5. Samsung Chromebook 3 Motherboard Replacement: Schritt 5, Bild 1 von 2 Samsung Chromebook 3 Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Use a spudger to gently pry the power cable cord upwards from the motherboard.
  6. Samsung Chromebook 3 Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Lift the battery up and out from the case.
  7. Samsung Chromebook 3 Motherboard Replacement, Motherboard: Schritt 7, Bild 1 von 3 Samsung Chromebook 3 Motherboard Replacement, Motherboard: Schritt 7, Bild 2 von 3 Samsung Chromebook 3 Motherboard Replacement, Motherboard: Schritt 7, Bild 3 von 3
    • Before you can get to the motherboard, remove the three 4.6mm screws from the port cover using a Phillips #00 screwdriver.
  8. Samsung Chromebook 3 Motherboard Replacement: Schritt 8, Bild 1 von 3 Samsung Chromebook 3 Motherboard Replacement: Schritt 8, Bild 2 von 3 Samsung Chromebook 3 Motherboard Replacement: Schritt 8, Bild 3 von 3
    • Then, use a spudger to begin flipping up the grey covers on the ZIF connectors.
  9. Samsung Chromebook 3 Motherboard Replacement: Schritt 9, Bild 1 von 3 Samsung Chromebook 3 Motherboard Replacement: Schritt 9, Bild 2 von 3 Samsung Chromebook 3 Motherboard Replacement: Schritt 9, Bild 3 von 3
    • Two more ZIF connectors to go!
  10. Samsung Chromebook 3 Motherboard Replacement: Schritt 10, Bild 1 von 2 Samsung Chromebook 3 Motherboard Replacement: Schritt 10, Bild 2 von 2
    • Use a spudger to disconnect the cables going to the speaker by prying outward to the right.
  11. Samsung Chromebook 3 Motherboard Replacement: Schritt 11, Bild 1 von 3 Samsung Chromebook 3 Motherboard Replacement: Schritt 11, Bild 2 von 3 Samsung Chromebook 3 Motherboard Replacement: Schritt 11, Bild 3 von 3
    • Use a spudger to lift the hinge locking the gold colored display cable in place.
    • Then gently coax the display cable from its connector using your fingers or a spudger.
  12. Samsung Chromebook 3 Motherboard Replacement: Schritt 12, Bild 1 von 2 Samsung Chromebook 3 Motherboard Replacement: Schritt 12, Bild 2 von 2
    • Use your Phillips #00 screwdriver to remove four 4.6mm screws from the motherboard.
  13. Samsung Chromebook 3 Motherboard Replacement: Schritt 13, Bild 1 von 1
    • Ensure all cables are clear and remove the motherboard.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
Austin Blakely
19.955 Reputation
53 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
140 Mitglieder
18.077 Anleitungen geschrieben
Ein Kommentar
Thanks for the great guide! I used it to remove the write protection screw on the back of the motherboard.
My Chromebook is model number XE501C13. The only difference I noticed is that there is one less screw on the outer plastic cover. Everything else is exactly the same!
Edward Fernandez - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 8
Letzte 30 Tage: 33
Insgesamt: 3,018
