Einleitung
This is a step-by-step guide to removing the track pad of the Samsung Chromebook 3. Prior to beginning this guide, you will need to remove the bottom case and the battery.
Was du brauchst
Place the Chromebook face down so that the bottom case is exposed.
Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
Use a iFixit opening tool to gently pry the case up from the vent on the hinge side of the Chromebook.
Locate the battery and remove the four 4.6mm screws at the corners which attach it to case using a Phillips #00 screwdriver.
Remove the three 2.3mm screws along the top of the trackpad using a Phillips #00 screwdriver.
Use a spudger to gently remove the adhesive tape on the upper left side of the trackpad.
There's more adhesive on the cable ribbon on the upper left side that connects the trackpad to the motherboard. Use your spudger to lift the cable ribbon up from the adhesive.
Use a spudger to lift the grey plastic piece locking the cable ribbon in place to its connection on the motherboard.
Take the end of the cable ribbon out from the connector.
From the keyboard side, nudge the trackpad down and around the lip on the upper edge and finally pull your trackpad out to freedom!
