Einleitung
This guide shows you how to access the LCD display inside your phone.
  1. Press button on back of phone below camera.
    • Press button on back of phone below camera.
    • While button is depressed, remove the back panel of the phone by sliding off (not shown in picture).
  2. Grasp the battery near the bottom with two fingers.
    • Grasp the battery near the bottom with two fingers.
    • Lift battery up and out gently.
    • Remove the rubber screw cover in the top left corner by prying it up with an iPod opener tool.
    • Use a Phillips #00 screwdriver to remove the six screws on the back of the phone. Three are evenly spaced on each side.
    • The upper right screw is 4.5 mm and the others are 6.5 mm.
    • Slide the iPod opening tool into the seam on the side of the phone and turn it slightly to unhook the eight clips.
    • There are three clips on each side and two at the bottom of the phone.
    • Once all eight of the clips have been unhooked, lift the back panel off of the phone.
    • Be careful not to remove the front panel. It is still connected to the phone chassis by a ribbon cable in the bottom right corner of the motherboard.
    • Using an iPod opening tool, undo the ribbon cable clip half way up the right side.
    • Carefully remove ribbon cable.
    • Remove the front faceplate by lifting it off of the phone chassis.
    • Using the iPod opening tool, unlatch the LCD ribbon cable.
    • Using a 1 mm flat head screwdriver, carefully pry under the lower left and right corners of the LCD screen.
    • The LCD is held in place to the chassis with adhesive strips.
    • Do not pry excessively hard or you may damage the circuitry on the back of the LCD.
    • Lift the LCD display out from phone chassis.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Mark Wyse
Mitglied seit 19.04.2011
59 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 15-15, Regan Spring 2011 Mitglied von Cal Poly, Team 15-15, Regan Spring 2011
CPSU-REGAN-S11S15G15
5 Mitglieder
5 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 1,789
