Einleitung
This guide shows you how to access the LCD display inside your phone.
Was du brauchst
Press button on back of phone below camera.
While button is depressed, remove the back panel of the phone by it sliding off (not shown in picture).
Remove the rubber screw cover in the top left corner by prying upwards with an opening tool.
Use a Phillips #00 screwdriver to remove the six screws on the back of the phone.
Slide the opening tool along the seam on the side of the phone and turn it slightly to unhook the eight clips.
Once all eight of the clips have been unhooked, lift the back panel off of the phone.
Using an opening tool or spudger, pry under the lower left and right corners of the LCD screen.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
