Was du brauchst
Flip the phone over and use your fingernail or an opening tool to remove the back cover.
Disconnect the following ribbon cables from the motherboard:
The digitizer and LCD assembly.
Headphone Jack and Earpiece.
Daughter board flex cable.
Antenna connector.
Remove the single Phillips screw that secures the daughterboard.
Remove the daughterboard.
Use a heat gun or an iOpener to heat the digitizer and soften the glue securing it.
Use an opening pick to break up the glue around the edges of the digitizer.
You may apply more heat if needed.
Remove the digitizer and any broken glass.
90 weitere Personen haben diese Anleitung absolviert.
11 Kommentare
I bought it on Ebay...
Follow the instructions in reverse order? Do you need glue for the new screen? What kind of glue? How is it applied?
Nor do they show how the new digitizer plugs in...
