Einleitung
This guide will teach you how to replace a camera in your Samsung Galaxy Note 10.1 2014 edition.
Was du brauchst
In diesem Schritt verwendetes Werkzeug:Spudger$2.99
Using the nylon spudger or plastic opening tool along the edges of the screen, separate the back case off of the device.
Remove the three 3mm screws on the top right side of the device with the Phillips PH000 screw head.
Remove the one 3mm screw on the top left side of the device with the same method.
Remove the gray rubber piece.
Use a spudger or fingernail to disconnect the blue antenna cable from the motherboard.
Remove the right speaker unit.
Remove the loudspeaker modules located on the parts where the screws were removed by using the black nylon spudger.
Place your finger on the thin black bar at the end of the ribbon tape and flip each one up.
Gently pull the ribbon tape on the battery away from the bar. Repeat this process for the second ribbon tape.
In diesem Schritt verwendetes Werkzeug:Phillips #000 Screwdriver$5.49
Remove the six 3mm screws around the battery with the Phillips PH000 screwdriver.
Lift up the battery from the bottom and situate the black nylon spudger underneath the battery.
Use the black nylon spudger to disconnect the multi-colored wires from the rest of the device.
Use the black nylon spudger to gently lift the motherboard away from the frame.
Remove the motherboard.
Eine weitere Person hat diese Anleitung absolviert.
