Zum Hauptinhalt wechseln
Samsung Galaxy Note 10.1 Front-Facing Camera Replacement
Was du brauchst
  1. Samsung Galaxy Note 10.1 Front-Facing Camera Replacement, Removing the Top Piece: Schritt 1, Bild 1 von 3 Samsung Galaxy Note 10.1 Front-Facing Camera Replacement, Removing the Top Piece: Schritt 1, Bild 2 von 3 Samsung Galaxy Note 10.1 Front-Facing Camera Replacement, Removing the Top Piece: Schritt 1, Bild 3 von 3
    • This is the back of the device and where you willl begin to take it apart
    • It is necessary to remove the silver piece covering the camera first before removing the bigger back piece.
    • Use the plastic opening tools to pry along the indicated box.
    • Lift up the silver piece to reveal the rest of the back cover.
  2. Samsung Galaxy Note 10.1 Front-Facing Camera Replacement, Removing the Back Cover: Schritt 2, Bild 1 von 3 Samsung Galaxy Note 10.1 Front-Facing Camera Replacement, Removing the Back Cover: Schritt 2, Bild 2 von 3 Samsung Galaxy Note 10.1 Front-Facing Camera Replacement, Removing the Back Cover: Schritt 2, Bild 3 von 3
    • Unscrew the three screws indicated by the red circles with the Philips #00 screwdriver.
    • Using the plastic opening tools pry along the bottom of the device, moving to the sides of the cover to the top.
    • Remove the back cover.
    • At this point use anti-static gloves or do NOT take it apart on carpet.
  3. Samsung Galaxy Note 10.1 Front-Facing Camera Replacement, Removing the Camera: Schritt 3, Bild 1 von 3 Samsung Galaxy Note 10.1 Front-Facing Camera Replacement, Removing the Camera: Schritt 3, Bild 2 von 3 Samsung Galaxy Note 10.1 Front-Facing Camera Replacement, Removing the Camera: Schritt 3, Bild 3 von 3
    • Start by lifting the white connector to remove the part indicated by the red polygon.
    • Gently pry along the camera hub to lift it out of its location.
    • This is your camera. Replace it with the new part.
  4. Samsung Galaxy Note 10.1 Front-Facing Camera Replacement, Front-Facing Camera: Schritt 4, Bild 1 von 3 Samsung Galaxy Note 10.1 Front-Facing Camera Replacement, Front-Facing Camera: Schritt 4, Bild 2 von 3 Samsung Galaxy Note 10.1 Front-Facing Camera Replacement, Front-Facing Camera: Schritt 4, Bild 3 von 3
    • Now that you have removed the rear-facing camera, you can access the front-facing camera.
    • To remove the front-facing camera, start by lifting the white connector to remove the part indicated by the marker.
    • Gently pull the front-facing camera out of its casing.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Rachel Dykes
205 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 17
Insgesamt: 341
