Zum Hauptinhalt wechseln
Samsung Galaxy Note II Front Facing Camera Assembly Replacement
Was du brauchst
  1. Samsung Galaxy Note II Front Facing Camera Assembly Replacement, Stylus: Schritt 1, Bild 1 von 2 Samsung Galaxy Note II Front Facing Camera Assembly Replacement, Stylus: Schritt 1, Bild 2 von 2
    • Grasp the end of the stylus and remove it from its slot in the midframe.
  2. Samsung Galaxy Note II Front Facing Camera Assembly Replacement, Rear Case: Schritt 2, Bild 1 von 2 Samsung Galaxy Note II Front Facing Camera Assembly Replacement, Rear Case: Schritt 2, Bild 2 von 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
  3. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: Schritt 3, Bild 1 von 3 Samsung Galaxy Note II Front Facing Camera Assembly Replacement: Schritt 3, Bild 2 von 3 Samsung Galaxy Note II Front Facing Camera Assembly Replacement: Schritt 3, Bild 3 von 3
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  4. Samsung Galaxy Note II Front Facing Camera Assembly Replacement, MicroSD Card: Schritt 4, Bild 1 von 3 Samsung Galaxy Note II Front Facing Camera Assembly Replacement, MicroSD Card: Schritt 4, Bild 2 von 3 Samsung Galaxy Note II Front Facing Camera Assembly Replacement, MicroSD Card: Schritt 4, Bild 3 von 3
    • If you have an SD card inserted, use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  5. Samsung Galaxy Note II Front Facing Camera Assembly Replacement, Battery: Schritt 5, Bild 1 von 2 Samsung Galaxy Note II Front Facing Camera Assembly Replacement, Battery: Schritt 5, Bild 2 von 2
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
  6. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: Schritt 6, Bild 1 von 1
    • Remove the battery from the midframe.
  7. Samsung Galaxy Note II Front Facing Camera Assembly Replacement, Midframe: Schritt 7, Bild 1 von 1
    • Remove the eleven 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
  8. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: Schritt 8, Bild 1 von 3 Samsung Galaxy Note II Front Facing Camera Assembly Replacement: Schritt 8, Bild 2 von 3 Samsung Galaxy Note II Front Facing Camera Assembly Replacement: Schritt 8, Bild 3 von 3
    • Insert your plastic opening tool between the midframe and front panel assembly on the side of the phone.
    • Slide the plastic opening tool down the seam.
  9. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: Schritt 9, Bild 1 von 3 Samsung Galaxy Note II Front Facing Camera Assembly Replacement: Schritt 9, Bild 2 von 3 Samsung Galaxy Note II Front Facing Camera Assembly Replacement: Schritt 9, Bild 3 von 3
    • Continue to run the plastic opening tool down the seam.
  10. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: Schritt 10, Bild 1 von 2 Samsung Galaxy Note II Front Facing Camera Assembly Replacement: Schritt 10, Bild 2 von 2
    • Carefully pry around the corner with a plastic opening tool.
  11. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: Schritt 11, Bild 1 von 2 Samsung Galaxy Note II Front Facing Camera Assembly Replacement: Schritt 11, Bild 2 von 2
    • Pry along the top of the phone with a plastic opening tool.
  12. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: Schritt 12, Bild 1 von 2 Samsung Galaxy Note II Front Facing Camera Assembly Replacement: Schritt 12, Bild 2 von 2
    • Push the plastic opening tool down to free the corner of the midframe from the display assembly.
  13. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: Schritt 13, Bild 1 von 2 Samsung Galaxy Note II Front Facing Camera Assembly Replacement: Schritt 13, Bild 2 von 2
    • Free the clips along the power button side of the phone.
    • Lastly, free the two clips along the top and bottom edge of battery compartment.
  14. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: Schritt 14, Bild 1 von 2 Samsung Galaxy Note II Front Facing Camera Assembly Replacement: Schritt 14, Bild 2 von 2
    • Lift the display assembly out of the midframe.
  15. Samsung Galaxy Note II Front Facing Camera Assembly Replacement, Front Facing Camera Assembly: Schritt 15, Bild 1 von 1
    • Remove the 3mm Phillips #00 screw from the front-facing camera bracket.
  16. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: Schritt 16, Bild 1 von 1
    • Remove the front-facing camera bracket.
  17. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: Schritt 17, Bild 1 von 1
    • Use the flat end of a spudger to disconnect the front-facing camera connector.
  18. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: Schritt 18, Bild 1 von 1
    • Remove the front-facing camera.
Abschluss
13 weitere Nutzer:innen haben diese Anleitung absolviert.
Sam Goldheart
465.854 Reputation
538 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
135 Mitglieder
17.198 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 9
Letzte 30 Tage: 17
Insgesamt: 11,778
