Zum Hauptinhalt wechseln
Samsung Galaxy Note Speaker Enclosure Replacement
Was du brauchst
  1. Samsung Galaxy Note Speaker Enclosure Replacement, Stylus: Schritt 1, Bild 1 von 2 Samsung Galaxy Note Speaker Enclosure Replacement, Stylus: Schritt 1, Bild 2 von 2
    • Grasp the cap of the stylus and remove it from its slot in the midframe.
    Frag FixBot
    Kommentar hinzufügen
  2. Samsung Galaxy Note Speaker Enclosure Replacement, Rear Case: Schritt 2, Bild 1 von 2 Samsung Galaxy Note Speaker Enclosure Replacement, Rear Case: Schritt 2, Bild 2 von 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the right of the rear-facing camera, near the volume rocker.
    Frag FixBot
  3. Samsung Galaxy Note Speaker Enclosure Replacement: Schritt 3, Bild 1 von 2 Samsung Galaxy Note Speaker Enclosure Replacement: Schritt 3, Bild 2 von 2
    • Lift and remove the rear case from the phone.
    Frag FixBot
  4. Samsung Galaxy Note Speaker Enclosure Replacement, Battery: Schritt 4, Bild 1 von 2 Samsung Galaxy Note Speaker Enclosure Replacement, Battery: Schritt 4, Bild 2 von 2
    • Insert your finger in the notch of the battery compartment.
    • Press the battery toward the rear facing camera while pulling outward.
    Frag FixBot
  5. Samsung Galaxy Note Speaker Enclosure Replacement, MicroSD Card: Schritt 5, Bild 1 von 3 Samsung Galaxy Note Speaker Enclosure Replacement, MicroSD Card: Schritt 5, Bild 2 von 3 Samsung Galaxy Note Speaker Enclosure Replacement, MicroSD Card: Schritt 5, Bild 3 von 3
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • For reassembly, push the microSD card into the slot until it clicks in place.
    Frag FixBot
  6. Samsung Galaxy Note Speaker Enclosure Replacement: Schritt 6, Bild 1 von 1
    • Remove the microSD card from its slot in the midframe.
    Frag FixBot
  7. Samsung Galaxy Note Speaker Enclosure Replacement, SIM Card: Schritt 7, Bild 1 von 2 Samsung Galaxy Note Speaker Enclosure Replacement, SIM Card: Schritt 7, Bild 2 von 2
    • Use a plastic opening tool, or your fingernail, to push the SIM card out of its compartment.
    Frag FixBot
  8. Samsung Galaxy Note Speaker Enclosure Replacement: Schritt 8, Bild 1 von 2 Samsung Galaxy Note Speaker Enclosure Replacement: Schritt 8, Bild 2 von 2
    • Slide the SIM card out the rest of the way with your thumb and remove it from the device.
    Frag FixBot
  9. Samsung Galaxy Note Speaker Enclosure Replacement, Midframe: Schritt 9, Bild 1 von 1
    • Remove the nine 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
    Frag FixBot
  10. Samsung Galaxy Note Speaker Enclosure Replacement: Schritt 10, Bild 1 von 2 Samsung Galaxy Note Speaker Enclosure Replacement: Schritt 10, Bild 2 von 2
    • Insert your plastic opening tool to the left of the power button between the midframe and the front panel assembly and pry.
    Frag FixBot
  11. Samsung Galaxy Note Speaker Enclosure Replacement: Schritt 11, Bild 1 von 3 Samsung Galaxy Note Speaker Enclosure Replacement: Schritt 11, Bild 2 von 3 Samsung Galaxy Note Speaker Enclosure Replacement: Schritt 11, Bild 3 von 3
    • Slide the plastic opening tool down the seam.
    Frag FixBot
  12. Samsung Galaxy Note Speaker Enclosure Replacement: Schritt 12, Bild 1 von 3 Samsung Galaxy Note Speaker Enclosure Replacement: Schritt 12, Bild 2 von 3 Samsung Galaxy Note Speaker Enclosure Replacement: Schritt 12, Bild 3 von 3
    • Insert your plastic opening tool to the left of the headphone jack between the midframe and the display assembly.
    • Slide the opening tool along the top edge of the phone.
    • Continue to run the plastic opening tool around the perimeter of the phone until the midframe is separated.
    Frag FixBot
  13. Samsung Galaxy Note Speaker Enclosure Replacement: Schritt 13, Bild 1 von 2 Samsung Galaxy Note Speaker Enclosure Replacement: Schritt 13, Bild 2 von 2
    • Remove the midframe from the display assembly.
    Frag FixBot
  14. Samsung Galaxy Note Speaker Enclosure Replacement, Speaker Enclosure: Schritt 14, Bild 1 von 1
    • Remove the three 3 mm Phillips #00 screws securing the speaker enclosure to the front panel assembly.
    Frag FixBot
  15. Samsung Galaxy Note Speaker Enclosure Replacement: Schritt 15, Bild 1 von 2 Samsung Galaxy Note Speaker Enclosure Replacement: Schritt 15, Bild 2 von 2
    • Remove the speaker enclosure from the display assembly.
    Frag FixBot
Abschluss
6 weitere Personen haben diese Anleitung absolviert.
Sam Goldheart
477.427 Reputation
538 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
122 Mitglieder
25.949 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 12
Letzte 30 Tage: 60
Insgesamt: 7,612
