Zum Hauptinhalt wechseln
Samsung Galaxy Note USB Board Replacement
Was du brauchst
  1. Samsung Galaxy Note USB Board Replacement, Stylus: Schritt 1, Bild 1 von 2 Samsung Galaxy Note USB Board Replacement, Stylus: Schritt 1, Bild 2 von 2
    • Grasp the cap of the stylus and remove it from its slot in the midframe.
    Frag FixBot
    Kommentar hinzufügen
  2. Samsung Galaxy Note USB Board Replacement, Rear Case: Schritt 2, Bild 1 von 2 Samsung Galaxy Note USB Board Replacement, Rear Case: Schritt 2, Bild 2 von 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the right of the rear-facing camera, near the volume rocker.
    Frag FixBot
  3. Samsung Galaxy Note USB Board Replacement: Schritt 3, Bild 1 von 2 Samsung Galaxy Note USB Board Replacement: Schritt 3, Bild 2 von 2
    • Lift and remove the rear case from the phone.
    Frag FixBot
  4. Samsung Galaxy Note USB Board Replacement, Battery: Schritt 4, Bild 1 von 2 Samsung Galaxy Note USB Board Replacement, Battery: Schritt 4, Bild 2 von 2
    • Insert your finger in the notch of the battery compartment.
    • Press the battery toward the rear facing camera while pulling outward.
    Frag FixBot
  5. Samsung Galaxy Note USB Board Replacement, MicroSD Card: Schritt 5, Bild 1 von 3 Samsung Galaxy Note USB Board Replacement, MicroSD Card: Schritt 5, Bild 2 von 3 Samsung Galaxy Note USB Board Replacement, MicroSD Card: Schritt 5, Bild 3 von 3
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • For reassembly, push the microSD card into the slot until it clicks in place.
    Frag FixBot
  6. Samsung Galaxy Note USB Board Replacement: Schritt 6, Bild 1 von 1
    • Remove the microSD card from its slot in the midframe.
    Frag FixBot
  7. Samsung Galaxy Note USB Board Replacement, SIM Card: Schritt 7, Bild 1 von 2 Samsung Galaxy Note USB Board Replacement, SIM Card: Schritt 7, Bild 2 von 2
    • Use a plastic opening tool, or your fingernail, to push the SIM card out of its compartment.
    Frag FixBot
  8. Samsung Galaxy Note USB Board Replacement: Schritt 8, Bild 1 von 2 Samsung Galaxy Note USB Board Replacement: Schritt 8, Bild 2 von 2
    • Slide the SIM card out the rest of the way with your thumb and remove it from the device.
    Frag FixBot
  9. Samsung Galaxy Note USB Board Replacement, Midframe: Schritt 9, Bild 1 von 1
    • Remove the nine 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
    Frag FixBot
  10. Samsung Galaxy Note USB Board Replacement: Schritt 10, Bild 1 von 2 Samsung Galaxy Note USB Board Replacement: Schritt 10, Bild 2 von 2
    • Insert your plastic opening tool to the left of the power button between the midframe and the front panel assembly and pry.
    Frag FixBot
  11. Samsung Galaxy Note USB Board Replacement: Schritt 11, Bild 1 von 3 Samsung Galaxy Note USB Board Replacement: Schritt 11, Bild 2 von 3 Samsung Galaxy Note USB Board Replacement: Schritt 11, Bild 3 von 3
    • Slide the plastic opening tool down the seam.
    Frag FixBot
  12. Samsung Galaxy Note USB Board Replacement: Schritt 12, Bild 1 von 3 Samsung Galaxy Note USB Board Replacement: Schritt 12, Bild 2 von 3 Samsung Galaxy Note USB Board Replacement: Schritt 12, Bild 3 von 3
    • Insert your plastic opening tool to the left of the headphone jack between the midframe and the display assembly.
    • Slide the opening tool along the top edge of the phone.
    • Continue to run the plastic opening tool around the perimeter of the phone until the midframe is separated.
    Frag FixBot
  13. Samsung Galaxy Note USB Board Replacement: Schritt 13, Bild 1 von 2 Samsung Galaxy Note USB Board Replacement: Schritt 13, Bild 2 von 2
    • Remove the midframe from the display assembly.
    Frag FixBot
  14. Samsung Galaxy Note USB Board Replacement, Motherboard Assembly: Schritt 14, Bild 1 von 2 Samsung Galaxy Note USB Board Replacement, Motherboard Assembly: Schritt 14, Bild 2 von 2
    • Use the flat end of a spudger to carefully disconnect the display cable connector.
    Frag FixBot
  15. Samsung Galaxy Note USB Board Replacement: Schritt 15, Bild 1 von 3 Samsung Galaxy Note USB Board Replacement: Schritt 15, Bild 2 von 3 Samsung Galaxy Note USB Board Replacement: Schritt 15, Bild 3 von 3
    • Use a spudger to disconnect the front-facing camera assembly cable connector.
    • Disconnect the headphone jack/earpiece speaker assembly cable connector.
    • Disconnect the digitizer cable connector.
    Frag FixBot
  16. Samsung Galaxy Note USB Board Replacement: Schritt 16, Bild 1 von 3 Samsung Galaxy Note USB Board Replacement: Schritt 16, Bild 2 von 3 Samsung Galaxy Note USB Board Replacement: Schritt 16, Bild 3 von 3
    • Disconnect the soft button cable connector with the flat end of a spudger.
    • Use a spudger to disconnect the USB board cable connector.
    • Disconnect the antenna cable connector.
    Frag FixBot
  17. Samsung Galaxy Note USB Board Replacement: Schritt 17, Bild 1 von 1
    • Remove the two 3.4 mm Phillips #00 screws securing the motherboard to the display assembly.
    Frag FixBot
  18. Samsung Galaxy Note USB Board Replacement: Schritt 18, Bild 1 von 2 Samsung Galaxy Note USB Board Replacement: Schritt 18, Bild 2 von 2
    • Remove the motherboard assembly from the display assembly.
    Frag FixBot
  19. Samsung Galaxy Note USB Board Replacement, USB Board: Schritt 19, Bild 1 von 1
    • Remove the three 3 mm Phillips #00 screws securing the speaker enclosure to the front panel assembly.
    Frag FixBot
  20. Samsung Galaxy Note USB Board Replacement: Schritt 20, Bild 1 von 1
    • Lift the speaker enclosure from the display assembly.
    Frag FixBot
  21. Samsung Galaxy Note USB Board Replacement: Schritt 21, Bild 1 von 2 Samsung Galaxy Note USB Board Replacement: Schritt 21, Bild 2 von 2
    • Use the tip of a spudger to disconnect the antenna cable connector from the USB board.
    • Remove the antenna cable.
    Frag FixBot
  22. Samsung Galaxy Note USB Board Replacement: Schritt 22, Bild 1 von 3 Samsung Galaxy Note USB Board Replacement: Schritt 22, Bild 2 von 3 Samsung Galaxy Note USB Board Replacement: Schritt 22, Bild 3 von 3
    • Push the flat end of a spudger under the USB board to separate it from the display assembly.
    • Insert the spudger at a shallow angle to avoid bending or damaging the USB board.
    Frag FixBot
  23. Samsung Galaxy Note USB Board Replacement: Schritt 23, Bild 1 von 1
    • Remove the USB board.
    Frag FixBot
Abschluss
51 weitere Personen haben diese Anleitung absolviert.
Sam Goldheart
477.640 Reputation
538 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
122 Mitglieder
27.503 Anleitungen geschrieben
6 Kommentare zur Anleitung
Using the Guides on online and the PDF guides made this repair easy and quick!
Joe - Antwort Teilen
It's not necessary to remove the motherboard (steps 17 and 18) to complete this repair. The flat flex running to the USB board can be easily slid out from under the motherboard with the motherboard still in position. Just omit steps 17 and 18 and the rest of the procedure works fine. I've done it twice.
Phil - Antwort Teilen
Where in England could I buy the USB Board part?
Craig Pyle - Antwort Teilen
USB board bought off ebay. Didnt need plastic opening tools, thumb nail worked easier than expected.
john dingley - Antwort Teilen
It's not the Galaxy Note GT-N7000!
costantino - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 36
Insgesamt: 25,102
