Zum Hauptinhalt wechseln
Einführungsvideo
Dieser Teardown ist keine Reparaturanleitung. Um dein Samsung Galaxy S22 zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Samsung Galaxy S22 Chip ID, Main Board Side 1: Schritt 1, Bild 1 von 2 Samsung Galaxy S22 Chip ID, Main Board Side 1: Schritt 1, Bild 2 von 2
    • IC Identification pt. 1:
    • Qualcomm SM8450 Snapdragon 8 Gen 1 Octa-Core Processor layered under a Samsung K3LK7K70BM-BGCP 8 GB Mobile LPDDR5 SDRAM Memory
    • Samsung KLUDG4UHDC-B0E1 128 GB NAND Flash Memory (UFS 3.1)
    • Maxim MAX77705C Power Management
    • Qualcomm PM3003 Power Management
    • Silicon Mitus SM3010 Power Management
    • Knowles MEMS Microphone
  2. Samsung Galaxy S22 Chip ID: Schritt 2, Bild 1 von 1
    • IC Identification pt. 2:
    • NXP Semiconductor SN220U NFC Controller w/ Secure Element
    • Qualcomm SMR546 RF Transceiver
    • NXP Semiconductor BGU8103 GPS / GLONASS / Galileo / BeiDou Low Noise Amplifier
    • Qualcomm 1G2W5 ? Front End Module (Likely)
    • Murata 451 ? Antenna Switch Module (Likely)
    • Infineon BGSA20UGL8 Dual SPST Antenna Aperture Shunt Switch
  3. Samsung Galaxy S22 Chip ID: Schritt 3, Bild 1 von 1
    • IC Identification pt. 3 (sensors):
    • Austria Microelectronics Ambient Light/Color/Gesture/Proximity Sensor
  4. Samsung Galaxy S22 Chip ID, Main Board Side 2: Schritt 4, Bild 1 von 2 Samsung Galaxy S22 Chip ID, Main Board Side 2: Schritt 4, Bild 2 von 2
    • Cirrus Logic CS35L40 Audio Amplifier
    • Cirrus Logic CS40L26 Haptic Driver
    • Renesas P9320S Wireless Power Transceiver
    • Qualcomm PM8350 Power Management
    • Qualcomm PMR735A Power Management
    • Vishay DG2730 2-Port DPDT Analog Switch
    • Goertek MEMS Microphone
  5. Samsung Galaxy S22 Chip ID: Schritt 5, Bild 1 von 1
    • Qualcomm PM8350C Power Management
    • Samsung S2MPB02 Power Management
    • Qualcomm PM8450 Power Management
    • Qualcomm PMK8450 ? Clock Generator
    • Maxscend MXD8643 SP4T Antenna Switch (likely)
    • Maxscend MXD8638C SP3T Antenna Switch
    • Maxscend MXDLN16GE GPS/GLONASS/Galileo/BeiDou Low Noise Amplifier
  6. Samsung Galaxy S22 Chip ID: Schritt 6, Bild 1 von 1
    • IC Identification pt. 3:
    • Qualcomm SDR735 RF Transceiver
    • Qualcomm QPM6815 Front-End Module
    • Qualcomm QPM6810 Front-End Module
    • Qualcomm QDM3572 Antenna Switch Module
    • Qualcomm WCN6856 WiFi 6/6E & Bluetooth 5.3
    • Qorvo QM45391 Front-End Module
    • Infineon BGSX22G5A10 DPDT Antenna Cross Switch
  7. Samsung Galaxy S22 Chip ID: Schritt 7, Bild 1 von 1
    • IC Identification pt. 4 (sensors):
    • STMicroelectronics 6-Axis Accelerometer & Gyroscope
    • STMicroelectronics Pressure Sensor
    • AKM Semiconductor 3-Axis Electronic Compass
  8. Samsung Galaxy S22 Chip ID: Schritt 8, Bild 1 von 1
Ein Kommentar
Why ifixit abandoned written teardowns here?
allanxp4 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 12
Letzte 7 Tage: 72
Letzte 30 Tage: 338
Insgesamt: 14,895
