Zum Hauptinhalt wechseln
Samsung Galaxy S4 Active MicroSD Card Replacement
Was du brauchst
  1. Samsung Galaxy S4 Active MicroSD Card Replacement, Rear Case: Schritt 1, Bild 1 von 2 Samsung Galaxy S4 Active MicroSD Card Replacement, Rear Case: Schritt 1, Bild 2 von 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  2. Samsung Galaxy S4 Active MicroSD Card Replacement, MicroSD Card: Schritt 2, Bild 1 von 1
    • Use a plastic opening tool, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Geoff Wacker
91.070 Reputation
89 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 10
Insgesamt: 1,511
