Zum Hauptinhalt wechseln
Samsung Galaxy S5 Active Battery Replacement
Was du brauchst
  1. Samsung Galaxy S5 Active Battery Replacement, Rear Case: Schritt 1, Bild 1 von 3 Samsung Galaxy S5 Active Battery Replacement, Rear Case: Schritt 1, Bild 2 von 3 Samsung Galaxy S5 Active Battery Replacement, Rear Case: Schritt 1, Bild 3 von 3
    • Insert your fingernail or plastic opening tool into the divot at the top of the rear-facing camera.
    • Gently pry and twist the flexible rear cover off the back of the phone.
  2. Samsung Galaxy S5 Active Battery Replacement, Battery: Schritt 2, Bild 1 von 3 Samsung Galaxy S5 Active Battery Replacement, Battery: Schritt 2, Bild 2 von 3 Samsung Galaxy S5 Active Battery Replacement, Battery: Schritt 2, Bild 3 von 3
    • Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
    • Remove the battery away from the phone.
Abschluss
To install the new battery, follow these instructions in reverse order.
11 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team 1-5, Hickman Fall 2014 Mitglied von USF Tampa, Team 1-5, Hickman Fall 2014
USFT-HICKMAN-F14S1G5
3 Mitglieder
7 Anleitungen geschrieben
1Leitfaden Kommentar
Awesome! I called around to the “WeFixYourPhone” places and they told me that battery couldn’t be replaced in a Samsung S5 Active, or they’d replace it for $40 if I bought the battery. Battery $13.50 for a 3200 mAmp one, Amazon Primed it to me. And the 45 seconds to replace it is no joke. That’s all it took. It took longer to get the Otter Box off the phone.
Lisa Swager - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 33
Insgesamt: 26,767
