Einleitung
This guide will show you how to replace the battery of your Samsung Galaxy S7 Active SM-G891AZAAATT. This guild will be helpful for when the battery is damaged or if it no longer holds a charge. Batteries may need replaced after being dropped, water damage, and after so many charging cycles. You will need to take the battery out to replace most other parts of the phone. No special skills required for this operation.
WARNING: Ensure your phone is powered off and unplugged from the charger prior to beginning this repair.
Was du brauchst
Melt the adhesive on the screen by applying a blow dryer directly on the screen.
Wedge the metal spudger in between the screen and the frame to begin separating them.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Use tweezers to remove the small plastic cover you just unscrewed.
Use tweezers to take out the middle button and its connection to the motherboard.
11 weitere Personen haben diese Anleitung absolviert.
4 Kommentare zur Anleitung
I would advise against using a metal spudger to remove the battery itself. While working at a device repair chain in the past, a coworker of mine punctured a battery with a metal spudger and destroyed the phone. Instead, use a sturdy plastic spudger to remove the battery. Otherwise, great guide!
I got the battery fixed but shattered my screen wish it was more informative on how to get out the screen
Would using the Anti-clamp with heat gun be better option?
There is a YT video where a famed smartphone repairer makes it look easy but in the comments people are saying they broke their screen. The videographer doesn’t reply to comments.
The guy uses a plastic (I think) business card to lift the screen, sliding it under at the bottom and gradually pulling the protruding sides of the card all the way to the top. I don’t have one so I bought a plastic yogurt carton. I am not sure how well its plastic will withstand heat. A source of heatproof plastic, or nylon card please?
How hot can I heat the screen? I have a non contact thermometer.
I also wonder whether the same glue will work. It doesn’t need to be waterproof.
I think I am going to destroy my phone. I wish there were rugged phone with changeable batteries. I love my S6 active but it is start to not run apps eg LINE.
