Einleitung
This guide will teach you how to remove and replace the motherboard in the Samsung Galaxy S7 Active.
Was du brauchst
Melt the adhesive on the screen by applying a blow dryer directly on the screen.
Wedge the metal spudger in between the screen and the frame to begin separating them.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Use tweezers to remove the small plastic cover you just unscrewed.
Use tweezers to take out the middle button and its connection to the motherboard.
Use tweezers to disconnect the front camera from the battery.
Use a Phillips 000 screwdriver to remove the screw covering the proximity sensor.
Use tweezers to remove the proximity sensor.
Set this aside for now.
Use tweezers to disconnect the front mic and the two cables that have been marked in the photo.
Use your hands and a metal spudger to lift the motherboard out of the phone.
Use a metal spudger to remove this connection.
3 weitere Personen haben diese Anleitung absolviert.
