Einleitung
This guide will teach you how to replace the rear camera on the Samsung Galaxy S7 Active.
Was du brauchst
Melt the adhesive on the screen by applying a blow dryer directly on the screen.
Wedge the metal spudger in between the screen and the frame to begin separating them.
Use tweezers to remove the small plastic cover you just unscrewed.
Use tweezers to take out the middle button and its connection to the motherboard.
Use tweezers to disconnect the front camera from the battery.
