Zum Hauptinhalt wechseln
Samsung Galaxy Tab A 10.1 S-Pen Speaker Replacement
Was du brauchst
  1. Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement, Battery: Schritt 1, Bild 1 von 2 Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement, Battery: Schritt 1, Bild 2 von 2
    • Remove all external power and turn off the tablet.
    • Insert a plastic opening tool between the screen and rear casing.
    • Pry the screen and rear casing apart.
  2. Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: Schritt 2, Bild 1 von 3 Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: Schritt 2, Bild 2 von 3 Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: Schritt 2, Bild 3 von 3
    • Remove the three green pieces of tape covering the white, black, and gold ribbon cables.
    • Use a spudger to flip up the retaining flap on the three ribbon cable ZIF sockets.
    • Pull the ribbon cables out of the sockets.
  3. Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: Schritt 3, Bild 1 von 3 Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: Schritt 3, Bild 2 von 3 Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: Schritt 3, Bild 3 von 3
    • Remove the ten 4mm Phillips #000 screws from the battery.
    • Use a plastic opening tool to pry up the battery.
    • Remove the battery.
  4. Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement, Speaker: Schritt 4, Bild 1 von 1
    • Use a spudger to flip up the retaining flap on the ribbon cable ZIF socket.
  5. Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: Schritt 5, Bild 1 von 2 Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: Schritt 5, Bild 2 von 2
    • Remove the ribbon cable from the socket.
  6. Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: Schritt 6, Bild 1 von 1
    • Remove the two 4mm Phillips #000 screws from the speakers.
  7. Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: Schritt 7, Bild 1 von 2 Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: Schritt 7, Bild 2 von 2
    • Use a plastic opening tool to pry the speakers out of the tablet
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Guneet Bawa
679 Reputation
4 Anleitungen geschrieben
UW Tacoma, Team S1-G5, Liner Spring 2018 Mitglied von UW Tacoma, Team S1-G5, Liner Spring 2018
UWT-LINER-S18S1G5
5 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 12
Insgesamt: 348
