Zum Hauptinhalt wechseln
Samsung Galaxy Tab 3 Kids Battery Replacement
Was du brauchst
  1. Samsung Galaxy Tab 3 Kids  Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Samsung Galaxy Tab 3 Kids  Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Before beginning this repair, make sure that the device is completely turned off.
    • Wedge the plastic opening tool in the seam between the screen and the back cover.
    • Slide the tool around all the edges and remove the screen from the back cover.
  2. Samsung Galaxy Tab 3 Kids  Battery Replacement: Schritt 2, Bild 1 von 2 Samsung Galaxy Tab 3 Kids  Battery Replacement: Schritt 2, Bild 2 von 2
    • Unplug the battery connection carefully using the plastic opening tool.
  3. Samsung Galaxy Tab 3 Kids  Battery Replacement: Schritt 3, Bild 1 von 2 Samsung Galaxy Tab 3 Kids  Battery Replacement: Schritt 3, Bild 2 von 2
    • Remove the four 1.2 mm Phillips #000 screws surrounding the battery.
  4. Samsung Galaxy Tab 3 Kids  Battery Replacement: Schritt 4, Bild 1 von 2 Samsung Galaxy Tab 3 Kids  Battery Replacement: Schritt 4, Bild 2 von 2
    • Use your hands to gently lift the battery up to remove it.
    • If it does not come off easily, there may be some glue underneath the battery and may need to be pried off with a spudger.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
ajhoffman
182 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 2-6, Nance Fall 2016 Mitglied von USF Tampa, Team 2-6, Nance Fall 2016
USFT-NANCE-F16S2G6
4 Mitglieder
10 Anleitungen geschrieben
2 Kommentare
Can any one help me , the buttery showing 100% then since then not booting I changed a new battery but still the same , any one can help me what could be the problem.
Thanks
khaledm2012 - Antwort
my screen broke
galixyman - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 1,988
