Einleitung
This replacement guide will walk you through how to replace the battery in the Samsung Galaxy Tab 3 7.0 Kids. Having a bad or broken battery can lead to poor battery life or unwanted shut downs.
For your safety, discharge your battery below 25% before disassembling your Galaxy Tab. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Was du brauchst
Wedge the plastic opening tool in the seam between the screen and the back cover.
Slide the tool around all the edges and remove the screen from the back cover.
4 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
Can any one help me , the buttery showing 100% then since then not booting I changed a new battery but still the same , any one can help me what could be the problem.
Thanks
